alas,Smokey has long passed away, some of the things he made was the first workable flow bench for cylinder heads,and fuel systems. he built the first engine dyno, you can take a tour through his shop in Florida. his flow bench was so good, many Nascar engine builders say it is more accurate than the modern one they have now.the guy was a bonifide genius,none of us had the right to be in the same room with him,that said when asked a question,Smokey would explain things till you understood it.a rare man
