So i finally got around to some more work on the bike. Built up a 96v polymer pack and hit the gas :
The first rather whimpy attempt was at 100amps battery current. I ramped it up to 150 amps for take 2. The bouncing was caused by the battery current limit kicking in and out.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
