Originally Posted by dcb
Problem is you throw a lot of efficiency away with a CVT when half the reason for converting to diesel is for maximum efficiency.
I think this efficiency loss with CVT is a bit blown out of proportion, though.
Is it really that inefficient ALL the time, or only while it's actually doing something?
When it is only cruising, shouldn't it be about as efficient as a basic belt drive of the same ratio? How often do you really plan on accelerating?
