Originally Posted by Christ
I think this efficiency loss with CVT is a bit blown out of proportion, though.
When it is only cruising, shouldn't it be about as efficient as a basic belt drive of the same ratio?
No, it's less efficient, even at fixed rpm when cruising.
It is a friction-based system, rather than a direct mechanical linkage, so you'll have some slippage.
