mpguino vss signal problem
Hello fellow modders, newb here, i have been searching for days with no luck on this problem. I have a 95 honda del sol and when i hook up to the vss wire, there is no reading on the mpguino and my speedo/odo stops working. I disconnected the mpguino vss wire and my speedo/odo starts working again. Is there a resistor or diode that i need to put in-line? Also, does anyone have any numbers for the setup so i at least have a starting point to calibrate? any help would be greatly appreciated. thanks
