Old 06-11-2011, 04:07 PM   #13 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Originally Posted by California98Civic View Post
So the 185's rev a little more than 2% less than the 175s?
You mean fewer revs and the correction should be relative to the stock tire, assuming it is the 175/70R13:
(907-927)/927 = -2.16%
That should mean the difference between these two tires in terms of MPG at 5th gear highway speeds would be a little over 1% maybe?
Only if GPS speed limits are being used. Changing the tire size also impacts distance measured and indicated speed. A slower turning tire will lead to a lower indicated speed so drivers are tempted to drive a little faster and into higher, aerodynamic drag.
In a car like an 80's CRX that's possibly a difference of 1.5-2.0mpg at highway speeds, no? If true and the 185s fit my CRX, that's what I would buy. SentraSE-R and others, such as arcosine, seem to have found that despite the larger sizes (worse aero) and heavier weights, that the taller gearing is a net benefit (on the highway, at least).
I'd have to see their data but I don't see anything wrong as long as the same-speeds were used.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
The Following User Says Thank You to bwilson4web For This Useful Post:
larrybuck (06-13-2011)
