Yes, that's correct.
With the compiling/programming problems you were having eariler, I wonder if it is compiling with the right peukert tables?
There is an if/else statement specifying which group of peukert multipliers to use. You may want to simply delete the if/else statement and the first group of peukert multipliers (1.30~1.20). This will force it to use the right tables.
