Thanks for the info puddleglum. I didn't know how that worked. Do you still wire the charger through the controller, or is it wired separately, and how would you do that, if you're hooking up your cables from the battery pack to the controller? I might have to take a second look at those e-bike packs. How does a BMS work? Can you hook one up to any old battery pack, or do you have to do some specialty wiring to get it to function properly?
