Station pressure is un-corrected pressure, and along with temp are the two main factors in how much power it takes to push what air there is (thick or thin).
Those two are also the main factors in bullet drop at longer ranges and make a BIG difference in your elevation adjustments.
Wind also affects bullet elevation and sometimes to a greater degree depending on how strong it is.
