Old 06-14-2011, 03:48 AM   #85 (permalink)
Heihetech
I didn't do anything you goof- GM did.
You goof suddenly switch "I did both" into "I didn't do anything", either played
a dirty game, or throw your "Limp-home" skill to GM? In fact, GM has been
playing tranditional cylinder deactivation (TCD) for decades, and TCD has
been applied to many of GM's products, but no one says GM's products are
in "limp-home mode". How did you reach such smart conclusion that GM may
like you very much?
Since TCD has been applied to many of GM's products, so I think it must run
smooth enough to satisfy the customers for decades, not only one day or two.
One of its problems of TCD is it's over-deactivation by 50% off the
cylinders. As a result TCD has to keep OFF most of the time during driving,
becoming less effective. Some TCD users reported it is only turned on when
coasting and going down-slope. Under these driving modes, modern engines
could cut the fuel off, yielding fuel savings even without TCD. So TCD's
utlization has become a major problem.
Also, it's incorrect to think GM has played with DCD. I have the evidence that GM
never know DCD until 3 weeks after my first DCD article was published,
and they felt a little bit surprise once a GM insider found out DCD ------
It happens only 3 weeks after online publication. It sounds like "CAR KING like GM"
is still in need of and didn't know about DCD technology ------ Someone named "GMisCARKING" has presented my DCD Publication to GM VP R&D Larry
Burns' Blog at:
http://fastlane.gmblogs.com/archives...y_we_live.html
GMisCARKING
Hi Larry! There is a new kind of cylinder deactivation tech called Dynamic Cylinder Deactivation(DCD). DCD is an electronic based cylinder deactivation solution. Controlled by electronic circuits and microcontroller, it deactivates all the cylinders inside the engine dynamically and in a balanced way. That is, all the cylinders inside the engine will be working in an intermittent mode, being activated and deactivated alternatively. The result would be a well balanced engine thermal condition under which engine performance could become the best, and also residual heat recovery by engine thermodynamic expansion during deactivation cycles.
Source: http://autoelectronics.com/mag/dynam...29/index1.html
