Old 06-14-2011, 02:49 PM   #2 (permalink)
cleanspeed1
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Any mechanically injected diesel will work well, the electronic diesels that don't use a piezo style injector work well also.
The VW would be the cheapest with the best part support.
The Mercedes products are better, but start with a well maintained, rust free unit or it'll nickel and dime you to death. Don't worry about the miles, just do a pre purchase inspection, and as long as it passes, get it.
The VAG powered Volvos and Audis ( same as the VW, but in 5 and 6 cylinder versions ).
The turbo versions are not affected by altitude as much, the only thing that slows a turbo diesel down is some malfunction in the fuel system or the engine itself.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
