Originally Posted by some_other_dave
The final drive gear is the ring and pinion. None of the gears mate with that, so that isn't a concern.
The two shafts that the gears ride on may be different (different diameter, different splines) and that would mean you could not swap.
-soD
that is essentially what I meant
