Well may have found the problem. I was reading the user manual to see if there was a thing in maintenance that I had forgot. Instead I saw "Fuel: Recommended 91 RON" Since I had a 150 mile trip to make I topped off the tank with 93 octane just to see if the recommended made a difference. I filled up again when I got home 159 miles later and shattered my old mileage record
EDIT: I thought I got 32 MPG, since that's where the gas pump shut off. However this morning I noticed that the gas gauge was down a bit even though I had just driven a few miles back to my house after filling, so i filled up again this morning, this time at the same station I had used when i left, and got a little over a gallon more in, so it is looking more like 26 MPG, but still a marked improvement.
It wasn't knocking so I hadn't thought about octane, but for some reason it made a difference. Not sure why though. Further research is needed to see what octane gives me the lowest $ per mile. Not exactly sure how to do scientific testing on this without draining the whole tank though.
Retired: Will add the new car once i manage to run a tank of gas through it.
