Old 06-15-2011, 06:42 AM   #127 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by Arragonis View Post
I suspect therefore the temp sensor is actually downwind of the turbo as load seems to increase it and it doesn't go down with airflow at speed which I would expect to have a cooling effect.
That's where is should be! Mine is before the turbo, so the engine/ECU has no idea how the turbo increased, and how much the intercooler decreased, intake air temperature. Good thing that PSA's injuneers didn't also put the boost pressure sensor before the turbo
Also noticed increased smoke with no grill block.
Helga smokes? Only when you floor it, or is she a regular? Filterless, or does she have a DPF?
