Old 06-15-2011, 10:37 AM   #188 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Arragonis View Post
What is the difference in weight between a V50 and an S40 these days ?
According to the online spec sheets : 9 kg / 20 lbs in favor of the S40.
That's not going to give a readily measurable difference - I've removed about 4 times that much from the V50.
Originally Posted by Piwoslaw View Post
Wow!
Your V50 has more problems than you suspected.
Yeah. Great.
At the very least it has confirmed that the shocks are due for replacement.
[*]The S40 is lighter and/or has better CdA.
The rear line on the S40 is pretty well streamlined, but fuel economy is officially only 0,1 L/100km lower / 1mpg higher on the S40.
Later versions have identical official FE numbers.
S40
Compared to V50
It has a slightly newer version of the lump and/or ECU.
That's a possibility, though the V50's ECU software has also been upgraded now and then.
Are the gearboxes exactly the same?
Looks like it, I'm getting the same rpm at the same speeds.
I'll copy the CoC pages though and check when I get my own car back.
Tell the service station crew about how big the difference is and ask why that could be.
Will do.
Maybe you could trade?
The trunk opening is so small I really don't want an S40
That was the main reason for not buying one back in 2005.
