The thing that normally wears out in motor oils is the residual alkalinity. Motor oil starts out with a pH of 9 to 10 and then it gradually drops in pH as acidic combustion byproducts gradually accumulate in the oil. Eventually these acidic byproducts use up all of the pH buffering agants in the oil and and the oil pH drops. When the pH gets below 6, the oil needs to be changed since its acidity then starts corroding the inside of the engine. So you can check the oil's pH and change it when it goes below 6.
