Old 06-16-2011, 11:38 AM   #23 (permalink)
wyatt
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
Originally Posted by California98Civic View Post
Does anyone think this use of the template reasonable? (See pic). The template suggests a possibly effective lid/spoiler shape. Is this a stupid use of the template?
This should be a fine use of the template. The problem is trying to make a compound curve like that out of coroplast... If I were you, I would make the front of your spoiler square, and at the back, taper the top of it in at a 45 degree angle, and let everything else fall where it will. I had put a 4' SedanKamm on my car, and this is the method I used, and it worked great with strong attached flow on the sides.
