Old 06-17-2011, 03:36 PM   #34 (permalink)
wyatt
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
Tablesaw Coroplast
I just use a plain old carpet knife (box cutter, utility knife) to cut through the inside layer of the cut, then bend on it. If you read through the tread about my SedanKamm, I basically say that I use a straight edge to cut along, then use the straight edge to bend along. It works well.
A table saw could be used easily enough, but coroplast is so light weight, that you will find it's really overkill.
