Originally Posted by deathtrain
the cars can produce steam from water. but no where near the volume needed to make any returns. power generation is my field of work so i think looking at a car. Putting a low RPM high output wind generator linked to the output shaft of a turbo would but out more. then again the returns would not really worth it on the return. but then again every little bit helps.
What exactly is going to drive the turbo in an ev?
