Old 06-20-2011, 12:34 PM   #2 (permalink)
Daox
The only issue with that motor is its designed for high voltage. That means you'd need a high voltage pack as well as an AC motor controller. Also, the rating of 2.8 kW isn't real high. It might be enough for a motorcycle, but packing in that many batteries into a motorcycle would be a real trick.
