Old 06-20-2011, 09:03 PM   #44 (permalink)
IamIan
IamIan's Avatar
Originally Posted by jamesqf View Post
The point, though, is that instead of a pure electric with a hard range limit (so if your batteries are drained miles from the nearest outlet, you're stranded), you have one that's much more efficient than an IC engined car, while still having virtually unlimited range.
I'll agree there is a efficiency benefit compared to a IC engined car.
But significantly less efficient than a BEV.
If carried out to run an entire trip on generator power ... I have my doubts the operating energy efficiency of the ICE would be increased enough for the vehicle to be any better energy efficiency than a straight ICE in a HEV type format.
Unlimited range ... I don't agree so much ...
An ICE generator that can only carry 1/5=~20% of the traveling energy needs is not enough to reach average operating energy needs ... the ICE generator would have to be sized for ~50% of the energy needs for the trip in order for it to at least reach the average energy needs point... once you reach the average energy needs point , the battery can buffer for the peak power needs and the ICE can run the vehicle for as far as it has fuel.
A ~20% energy needs generator is only capable of limp home mode at speeds slow enough that you are consuming ~80% less energy from Aerodynamics + Rolling resistance + etc... That is a significantly slower average rate of travel.
I suspect the ~20% energy needs generator will require more space and weight than adding another 20 miles for range to the batteries would ... which in the given scenario would result in a 100% BEV trip... and have a better total vehicle operating energy efficiency.
I agree there is a break even point where eventually the total needed range is too far for a BEV to do ... But 100 miles , or even 200 miles is far enough anymore.
I also agree without adequate battery swapping stations , or fast charge stations , there is a convenience benefit to a Range extending ICE generator that can handle the average operating energy needs for those long trips that are beyond the range abilities of the BEV.
I also think the % of the population that actually needs that far of a distance in one shoot frequently enough to justify it , is very small.
For example :
I rent a U-Haul to move ... but do not own one and drive it daily for a commute vehicle ... I don't need those vehicle features frequently enough to justify it myself ... There is a % of the population that does ... and for them sure go ahead ... and there is a % of the population that just wants it , and will pay for it ... and for them sure it's there money , spend it any way they like.
