Old 06-20-2011, 09:57 PM   #3 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Driving technique can get fairly high mpg's. The Toyota Trucks do engine off coasting well with a bump start at the end. With the tail end easy to aeromod, you might surprise yourself how well the motor can do. It is a tractor motor, so use it at extreme low rpms for best results.
I would say if the price is right and you fit in the cab, give it a try. It should be reliable in any case.
Nissan Versa Aeromods
