Originally Posted by pnikolaj
... especially when you are working with electronics.
I failed to notice the pin-outs on the last page of Cougar LCD - PCB Assembly Instructions - Rev0.pdf and used page 9 of CougarLCD_User_Manual_Rev_1_3.pdf to determine the connections. I assumed that the pins read left to right and now realize after looking real close at the schematic that I applied 98 volts to the 12V feed for the buzzer.  The board is now toast.
Pnikolaj,
Very sorry to hear about the board. If I had a spare I'd give it to you.
Schematics and wiring diagrams should never be used to determine physical orientation/location of connectors. Typically the silkcreen (overlay) on physical PCB would have a pin 1 indicator but I didn't have the room
An overlay drawing (like I included in the assembly instructions)or pin 1's called out on a picture of finished assembly are the next best thing.
I'll add the overlay to the manual right after wiring diagram. On wiring diagram I'll add note to reference overlay for pinout orientation. I'll make it part of package for version 1.4 release.
