Old 06-21-2011, 02:29 PM   #5 (permalink)
Arragonis
The PRC.
I agree with Angmaar, I started getting this last Autumn without using an unbranded station and found that some of the pipeage from the turbo to the inlet manifold leaked at full boost. It was clear one day and then the next the Merc I had just removed from tailgating was no longer visible - I don't do that any more
A touch of duct / gaffer tape has fixed it temporarily - well for nearly 12 months now. It may be worth giving the pipes a squeeze / pull and see if anything is loose. My gaps were on the reverse side and hard to spot without sticking my head deep into the engine bay.
EDIT - A cleaning additive is worthwhile too, maybe every 3-5 tanks depending on how hard you drive. I use Redex 0-60 which also has Cetane boosters.
