Old 06-21-2011, 06:28 PM   #84 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by valerun View Post
Hi Guys, not sure if I am missing something but what's the point in building your own DC-DC to drive IGBTs again? I mean these are $10 parts at digikey and such - all integrated, with +15/-15V outputs which a perfectly suitable for IGBT modules with +-20V gate drive limits... You can get a 2W version which is sufficient for driving a 400-600A module at up to 12-15kHz (there is no point in using anything higher than 10kHz anyway for a motor controller - you only end up multiplying switching losses). If that's not enough, for ~$25-30 you can get a 10-15W version which can drive an array of enough IGBTs to produce output currents that you shouldn't be trying to produce anyway ;-))
I'm not trying to be a pain but just trying to understand if I am missing some additional motivation...
The main purpose behind the dc-dc converter is for the AC controller where you need 4 to 6 of them.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
