Thanks Adam - got it. Still, it's a $7.34 part (in quantity of 10, 102-2096-ND on DigiKey) that's not going to fail on you, does not need to be debugged, switches at 1-2MHz and is super-compact, can be placed right at the tiny PCB sitting on IGBT terminals, etc. By the time you are done with all the components you need to create a 14-output DC-DC (7 +X V, 7 - X V), I doubt you will be saving more than $10, if that...
