Old 06-21-2011, 07:44 PM   #55 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I will refrain from mentioning EPA considerations when motivating a vehicle, but a typical $500 generator is still not going to be a model of efficiency, still a very lossy proposition, and the jury still isn't impressed with the series/parallel volt.
"sensibly" means convert the gasoline into miles most efficiently, hard to do when you make the engine spin a generator to run a controller to run a motor, especially when you are already at 520ish g/kwh before you get to the controller.
The kohler is about 13.4hp. Which is maybe 10kw, so you lost %25 of your gas right there to make 7.5kw, let me know when this is sensible.
