Mora,
Then I'd just wire in a 500 ohm potentiometer between sender wire and ground. See what resistance creates a full & empty condition. Will probably be in the 30~250ohm range. That will tell us what value to make R20 and if PWM needs to be inverted or not.
Sent you a pm with email
