Old 06-22-2011, 10:17 AM   #1 (permalink)
Daox
3-Cyl. Passat Illustrates ‘Extreme Downsizing’
If only it were to ever get into production... Heck, I wouldn't mind a 1.2L in my way smaller Paseo!
Here at Bosch’s test track, an ’09 Volkswagen Passat “Extreme Downsizing” demonstration vehicle has a new 1.2L 3-cyl. engine from Mahle Powertrain with a single-stage turbocharger from the JV.
And despite its diminutive size, the engine performs remarkably well in powering the spacious 5-passenger Passat wagon around Bosch’s high-speed oval at more than 112 mph (180 km/h).
With a manual transmission, the engine is a bit hesitant at launch, but throttle response is excellent at mid-range and high engine speeds, with a fat torque curve that peaks at 210 lb.-ft. (285 Nm) from 1,600 to 3,500 rpm.
A casual driver would be unlikely to guess such a small engine is underhood.
The 1.2L engine is rated at an astounding 161 hp at 5,000 rpm, compared with 121 hp in the production engine it replaces, a 1.4L TSI direct-injection gasoline 4-cyl.
And mileage isn’t bad, either. Bosch pegs fuel consumption at 40 mpg (5.9L/100 km), based on the European driving cycle.
Maximum boost pressure of the demonstration single-stage turbocharger is 36 psi (2.5 bar). The prototype engine also integrates cam phasing on both intake and exhaust sides of the valvetrain.
Bosch officials say the engine installation in the Passat is merely a coincidence and is not intended to suggest Volkswagen is the first light-vehicle customer for the new turbochargers.
The Following 2 Users Say Thank You to Daox For This Useful Post:
California98Civic (07-01-2011), Frank Lee (06-22-2011)
