To say that there will be no gain is really not true either, if you lived in a hilly area it might allow you to hold OD or more likely the TC locked on an automatic. The power can be used when accelerating as well. It really depends on the engine you are starting with, if its a chrysler 2.2L chances are it can use the power, if it is a 5.0 mustang chances are it wont. Making the island bigger increases the potential to be operating in conditions that put you on the island, also if you look at the island in post 60, the island is also a hint wider as well with the turbo.
On a diesel a turbo should always help.
