Making the island bigger increases the potential to be operating in conditions that put you on the island, also if you look at the island in post 60, the island is also a hint wider as well with the turbo.
It's not worth it at all. While accelerating, I can stay in that island from 5mph all the way up to 80mph turbo or not. I can't stay in it while cruising. You know why? Because I can't use that much torque. The island needs to be brought south, so I can stay in it without accelerating, just like I said before.
If you really understand the concept of torque, then go ahead and explain to us why P&G is more efficient than cruising, and use the map to back up your points.
