An interesting use for a serial hybrid:
(click on image for link)
The technology, which is intended for later use also in large-scale aircraft, will cut fuel consumption and emissions by 25%, compared to today’s most efficient aircraft drives, according to Siemens.
Based on Diamond Aircraft’s HK36 Super Dimona, the E-Star’s propeller is powered by a 70 kW electric motor from Siemens. Electricity is supplied by a small Wankel engine from Austro Engine with a generator that functions solely as a power source. A Siemens converter supplies the electric motor with power from the battery and the generator.
Fuel consumption is low since the combustion engine always runs with a constant low output of 30 kW. A battery system from EADS provides the increased power required during takeoff and climb. The battery is recharged during the cruising phase. The plane is able to start noiseless with the electric drive and can fly over long distances. During test flights, it was airborne for about two hours.
[Emphasis is mine.]
