Make sure your radio has very good electrical connections.
The optimum would be to have a fused +12 and a GND lead running directly to the battery. The one problem with this is that your accessory switch would not turn off the radio.
Also check that your antenna connection is in good order.
Mount the cougar as far away from the radio as possible.
