Old 06-26-2011, 09:25 PM   #29 (permalink)
cleanspeed1
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Originally Posted by EdKiefer View Post
I believe you have that backwards , wider separation = less overlap =better low end and narrow separation =more overlap = higher peak efficiency rpm
OP : 500cfm is all you need for low -mid range on 350 .
I'll look further into this, thanks for the correction.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
