Originally Posted by Air-Hybrid
I think I read somewhere that the Prius already uses PCMs to store coolant heat for quick-up-to-temp restarting. . . .
The North American, NHW20 model (2004-09) has a thermos that holds hot coolant. No phase-change heat storage.
The current ZVW30 model has a heat exchanger behind the catalytic converter to tap exhaust heat and rapidly heat up the block.
Bob Wilson
2019 Std. Range Plus Model 3 - 134 MPG3 || 2014 BMW i3-REx - 117 MPGe, 39 MPG
JuiceBox 40 Pro (240 VAC, 40 A), KHONS portable (120-240 VAC, 12-32 A)
Retired engineer, Huntsville, AL (
five times AutoPilot saved.)
