well, hit a slight wall (literally), the fog light bracing completely covers the back end of the opening. so the only real way to attach these is to remove the fog light and the bracing itself, which I certainly dont mind doing, but its going to take quite a bit more work than I was prepared for today.
other than that, its coming along pretty good, I have the coro cut and shaped and the holes I will need to use for attaching it set and most of the trimming is done.
only a few things left before putting them on now, but not sure if Im going to be done today as its going to take quite a bit of work to get those fogs off...
and on top of it, the batt in my cam is dead so no pix yet.
~Mike
