Originally Posted by oldbeaver
Question: how did you cope with the electronic control of the engine?
Did you install and connect all sensors and did you install the proper computer?
The least troublesome way to do swaps like these is to transplant all engine related accessories, control gear and instruments along with the lump.
If you follow a wire and it doesn't go to something straightforward that you can easily duplicate, swap it over.
On cars with anti-theft gear built in, you might need to swap even the ignition key lock and keys.
Re-routing / lengthening / shortening some wires is far easier than sorting out and fabricating the right signals to go to the right places on your own.
