Old 06-27-2011, 12:39 PM   #88 (permalink)
jamesqf
But I believe the transition to lean burn mode is still fairly evident: The instant fuel consumption drops noticeably on the FCD (fuel consumption display); throttle response becomes somewhat deadened and uneven; and there are occasional "stumbles" from the engine.
That's all normal, except for the stumbles - at least, I've never noticed that. Lean burn is very evident on the instant FCD. If you cruise on a level road, you'll notice that it automatically goes out of lean burn for a few seconds every couple of minutes, in order to purge the secondary NOx catalytic converter, and you see mpg drop from 100+ to 50-70. Sometimes you need to play with the throttle just a bit to get it back into lean burn...
The Following User Says Thank You to jamesqf For This Useful Post:
MetroMPG (06-27-2011)
