Thread: Free Air Con
Old 06-27-2011, 02:41 PM   #2 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Welcome to ecomodder.
Originally Posted by topcat View Post
My scangauge shows me that it is possible to get free air con during in-gear deceleration, as an alternative to (_horror_) braking. I call it air con braking.
As the wheels are driving the engine and its accessories.
You won't notice it, but it'll brake a tiny bit harder.
Engine braking (or DFCO as it's called on here, for Deceleration Fuel Cut-Off) is still braking.
Slightly less of a horror, but it still reduces your fuel economy.
Start coasting in neutral as much as you can , in preference to engine braking.
Find the transition points on your regular trips : the speed you need to carry at a certain spot to make it to the next point (a cross-road, traffic light, ...) When you get there, repeat the process to the next point.
