Old 06-27-2011, 10:30 PM   #18 (permalink)
379Kcivic
Thanks for responding. I''m pretty sure that it was above F when I filled up; I'll double-check that the next time I fill up. But I did make three attempts to continue filling after spilling/overfill when the pump read just 6.05 gallons.
Additional issues:
1. The upshift light ceases working after the engine is up to temperature (ECU?)
2. The idle is running about 1100rpm once warm (idle control motor?)
3. When the car is still cold, the rpm's seem to be sticking in between shifts (??)
4. Occasionally the engine dies when coasting to a stop (O2 sensor?)
5. Finding a driver's seat.
And of course the transmission is toast.
Thanks
