Old 06-28-2011, 10:42 AM   #9 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by doomz78 View Post
I have an upper and lower grill block. I have a hole maybe the size of a softball on the lower grille. I drove 220km today and the engine was getting a bit hot. 225 was the max
I wouldn't be comfortable with 225F.
The engine still needs some cooling when the weather is getting hotter.
After a while, if you want MPG increases i believe that you have to start splitting a few hairs. So That is what I'm doing.
Yeah, you get a bit here and a bit there, but it all adds up.
I was thinking of removing the hubcaps cause the steel rim is smoother and more aerodynamic. and i would also shed a few pounds with the hubcaps off. Maybe 3 -5 lbs.
If the hubcaps are not as smooth as the steelies, that's say 4lbs of rotating and unsprung mass removed, which is a good thing.
