Originally Posted by Phantom
Can you get a vid of the hho gas burning?
He is acually calling it Hydrogen and Oxygen, which is correct.
He also isn't making any claims but is wanting to test it.
A couple of notes for you to consider though
1. You might want to put some kind of control preferably a pwm to control the output to match throttle.
2. Hydrogen burns much faster than gas, so you will want to retard your timing for best results.
3. The best results I have found in actual scientific documentation was a 5% improvement. I'm pretty sure they were using a tank of H2 and correcting for the energy content of the Hydrogen. Most only see a 0-2% improvement.
Your system would either be running off of the alternator or battery. Using the alternator would probably be the best for you to be able to record any improvement because using a battery and charging it from an outside source is imputing energy that is probably not being accounted for which would invalidate your results.
