Old 06-29-2011, 11:24 PM   #17 (permalink)
winkosmosis
Originally Posted by CFECO View Post
Very true, but since I will have to get better tires, that will take a higher pressure, I can go taller also. This will fill in the wheel well better and give me an effective higher gear ratio. Not much can be done with the axle unless I went with IRS, say from a Hummer H-1. Thats too much reconstruction for this truck.
Never heard of a truck getting better gas mileage from taller tires. I think the combination of bad aerodynamics and higher weight vs cars leaves you with very little headroom for taller "gearing".
My Cherokee has a 2" lift, a front skid plate that directs air down, and 31" tires (stock are 28"), and I only get 16mpg.
