Old 06-29-2011, 10:57 PM   #10 (permalink)
camopaint0707
Knight - '07 Chevy Cobalt LS
Chevyteg - '95 Acura Integra LS
Originally Posted by Diesel_Dave View Post
In theory, I would think it would hurt your FE, as it would create a lower pressure going into your intake (because it's in a wake) Now, how much it would hurt I don't know. I've wondered myself about the benefits/drawbacks of a forward-facing hood scoop--it'll probably hurt aero but the ram air should help the engine. A rear-ward facing hood scoop would basically give you negative ram air I would think.
Originally Posted by mcguire View Post
Look up "cowl induction". There is a high-pressure area at the base of the hood on most cars (AFAIK); a hood scoop facing rearward at the rear of the hood will take in air from that high pressure.
I have no idea how it will affect the aerodynamics of the vehicle, compared to a forward-facing scoop on the front of the hood or no scoop at all.
Yes I'm aware of cowl induction but most of those are for performance. I just want a little cooler air into the engine. The air wouldn't even hit near the intake at all more like the top of the block. I would just like to know if or how bad it would mess up the aerodynamics.
