...a similar "frustration" is how Detroit seems "stuck" on HP and not MPG.
...for example, when GM first came out with their 265 cid small block engine, they keep spiraling UPwards, always seeking higher HP, instead of doing this:
1) if the 265 cid can produce 200 hp--and they "knew" there was more where that came from--lets reduce the displacement to 250 cid and see if we can STILL get 200 hp.
2) then, lets try it again; lets reduce the displacement some more, to 200 cid, and see if we can STILL get 200 hp.
3) repeat again!
...that way, they would've eventually had a 100 cid engine producing 200 hp! It would've been SMALLER, LIGHTER and very HP-dense for its size. AND, it would've been ECONOMICAL, too!
...a Mopar example was the LA 273 cid engine which produced 235 hp with a four barrel carburetor, but was replaced by a 318 cid 2BBL which produced 230 hp!
...it's obvious, they ALL took the "easy" way (BIG, BIGGER & BIGGEST) rather than the "smart" way.
