Thread: MPG calculators
Old 06-30-2011, 05:28 PM   #8 (permalink)
sgtlethargic
Originally Posted by TheEnemy View Post
You would adjust the engine efficiency for the range you would be running the engine in.
A larger engine would be less efficient at the same power load as a smaller engine.
Okay, so how does one go about estimating the efficiencies of different engines?
Add to that no two engines are the same even if they are the same displacement, year, options...etc.
It's an estimator, so that seems like splitting hairs.
The point being, I can't find the MPG estimator I used the other day.
