Thread: MPG calculators
Old 06-30-2011, 05:50 PM   #13 (permalink)
sgtlethargic
Originally Posted by TheEnemy View Post
Your talking about the Ford Ranchero?
Does it have an electric, clutch or direct driven flex fan?
Punching my best guess into the calculator I come up with a max of 22mpg between 35 and 45 mph. That is assuming you have a clutch fan, and a standard transmission.
weight 3500 lbs
crr .008 (a bit low I think)
Cd .45 (typical for a truck)
frontal area 20ft^2
Engine efficiency .20
Drivetrain efficiuency .85
Paracitic overhead 5000 (those fans really pull power)
Yes, a 1961 Ranchero. I'd have an electric fan, standard trans, it weighs ~2400 lb, and it's Cd is probably close to the .34 default.
Here's what I did:
Vehicle weight: 1088.6 kg / 2400 lbs
Crr: .015
Cd: .34
A: 1.9 m2 / 20 ft2
Fuel energy density (Wh/US gal.): 33557
Engine efficiency: .20
Drivetrain efficiency: .95
Parasitic overhead (Watts): 0
rho: 1.22 kg/m3
... which yields 29.4 mpg at 65 mph, and 32.6 mpg at 60 mph.
