Originally Posted by joggerfogger
Looking good, JF!
Sketchup tip: Before connecting front-rear lines (for skin) between bulkheads right click on segments (lines, arcs) to access entity properties. Tweak the number of segments per arc as desired. You can make them as smooth or coarse as you want. That effectively gives manual control to "mesh" the rendered surface with appropriate size/shape triangle patches.
Keep up the great work! If I can't build mine now (if ever) I may as well try and help somebody else build theirs.
