Old 07-01-2011, 03:04 PM   #51 (permalink)
Pendragon
Originally Posted by California98Civic View Post
The tape that I still have to use to seal the gaps and edges has damaged the paint job with sticky glue that I can't get off (yet). Bummer. Magnets hold it down via straps to the lid's underside. And I have tested the straps hold, but the tape seals gaps and smooths edges. I'm pausing this project until I'm better skilled in fabrication. I'll test the current build once I get the paint clean and devise a better way to seal gaps. Good luck with your efforts Brucepick. I'll be following. On to my airdam today after work and yard projects...
You might try some bug and tar remover with a soft cloth to remove the adhesive. If that does not get it all there may be a product at the drug store used to remove bandage adhesive from skin, but they usually come in the form of a wipe. If you wind up using rubbing alcohol, wash the area right away and put some wax on it as the alcohol tends to dry things out if left there to its own devices.
The Following User Says Thank You to Pendragon For This Useful Post:
California98Civic (07-01-2011)
