Old 07-01-2011, 04:05 PM   #4903 (permalink)
jackbauer
jackbauer's Avatar
Yeh i saw that , thanks. What's the story with the traction voltage sensing? I saw a max_voltage parameter on rtd. Can i set the point at which the contactor closes etc? Will it shutdown on low voltage?
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
